Hello,
I have a few mpegs that show wrong time. For example one of them has 30 seconds, and when I open it in Media Player Classic, it says it has 17 minutes. It's annoying because I can't use fast forward (or backward) properly.
I found some tools, but before trying I want to ask what is the best tool for this thing (if any)
http://www.pixeltools.com/tech_tip_stream_header.html
http://www.gromkov.com/faq/faq2004-0085.html
http://public.seconis.net/info/HeaderRepair/MPEG-HeaderRepair_en.htm
thanks
depends what kind of errors the files have. You may first try to demux them with PVAStrumento or ProjectX. They may correct file structure without re-encoding, if the faults are not critical. Then remux streams with MuxMan - it accepts only standard video frame size, though.Originally Posted by ziptip
Program to repair corrupt video files
By adrien23 in forum Newbie / General discussionsReplies: 1Last Post: 13th May 2011, 19:32 -
Which program is best if you just want the right time stamps?
By Spiny Norman in forum SubtitleReplies: 3Last Post: 6th Aug 2010, 16:48 -
How to repair a damaged MPEG-file ?
By d98rolb in forum Video ConversionReplies: 2Last Post: 5th Oct 2009, 03:03 -
How to repair broken frames in MPEG/DVD videos
By misterbean in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2008, 00:02 -
Good program to repair broken dvd files?
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2008, 19:22
