I have an Oppo DV970 DVD player which after a bunch of fooling around I discover will not play MP4. It was a teaser because it opens an MP4 file on a thumb dive and flashes up a little video and quits. On a DVD only sound is produced.
I am a dangerous newbie when it comes to working with the contents of video containers but from what I understand to play this file I must convert it to something in an AVI container. If I understand the variable video bit rate is the issue. I have successfully converted with WINAVI to XviD but the video quality is degraded and the file is 3x the size, can this be avoided?
I have installed Mpeg StreamClip and Quicktime Alternative 1.8.1.0 but this will not run. I believe I followed the installation instructions correctly.
Any help with getting Mpeg StreamClip to run or a suitable alernative method would be appreciated.
Thanks, John.
Or, if you want an alternative, just convert it to DvD format instead (MPEG-2). Although you will need a bit more bitrate than with using Xvid (but not 3x like before), but it will be playable on every DvD player out there - no need for AVI.
A simple tool that will do it all with your MP4 files is ConvertXtoDvD (not free though).
MP4 -> MPEG-2/DvD -> Author -> Burn
I've never tried it, but I hear a similar free version is FAVC.I hate VHS. I always did. -
Thanks Baldrick and PuzZLeR. I have installed Xvid4psp which seems to be a little broken. Following Baldrick's instructions Xvid4psp opens the file, caches it and then presents an audio track window, after audio track selection the program presents a black window and hangs. However if I continue with encode the job seems to be done.
I updated dotnetfx3setup 3.0.4506.30 after its installation, should I have done this?
Any thoughts. John.
Editing MP4 files with H.264 (AVC) video and AAC audio
By Ahari in forum Newbie / General discussionsReplies: 4Last Post: 16th Apr 2012, 17:30 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 16:25 -
Hi can anyone tell how to play a mp4(h.264 + AAC) file using dshow filter?
By kalpanaanb in forum Newbie / General discussionsReplies: 1Last Post: 31st Mar 2009, 09:58 -
DV --> MP4 (H.264/AAC) With Datecode Subtitles, Timecode, and Metadata
By funkydoobie in forum Video ConversionReplies: 1Last Post: 30th Jan 2009, 01:40 -
Beginner: What is the best software for DVD to mp4(H.264/AAC)?
By Liquidus in forum DVD RippingReplies: 11Last Post: 1st Jul 2008, 19:48
