Hi, I've got a question for you all.
I'm currently reading about the new HD formats and all the supported codecs and one thing that I realized is that Microsoft has an implementation of VC1 (or WVC1) and Blu-ray drives are compliant with VC1. My question is this; is it possible to convert (without recoding) a wmv to something compatible with Blu-ray drives? For example; take a wmv, extract the elementary stream to .vc1 and remux it into a .TS (or .PS, .M2TS) and then author a Blu-ray disc?
Nic
Thanks for the reply.
So I guess by this comment this means the two VC1 implementations are the same.
I gave this method a go, seems to work fine, amazing.
One thing I can't seem to get to work though is loading the ts (If I create that using tsmuxer instead of a Blu-ray disc) in VideoReDo Plus. All I keep getting is "Cannot find PAT packet in program stream".
I understand that a VC1 elementary stream lacks metadata that would be useful when rebuilding a ts file. Is there a tool that could help me with rebuilding the missing info in the PAT header? I tried ProjectX but no luck. It can't seem to find the video stream (Or maybe I'm doing something wrong).
Thanks again!
Nic -
Glad to hear that.I gave this method a go, seems to work fine, amazing.
I presume VideoReDo supports only MPEG-video in transport streams
Alas, some of the finest applications, such as VideoReDo, only support MPEG. We await the day when such will be readily available for future formats such as HD, or WMV/VC-1 or H.264, etc. Of course, this was the case with only MPEG-2 only a few years ago...
I hate VHS. I always did.
Codec problem in ASF/wmv file (wvc1)
By ezzeee1 in forum EditingReplies: 7Last Post: 25th Feb 2011, 21:16 -
Avidemux and WVC1
By rjc7394 in forum Video ConversionReplies: 1Last Post: 18th Oct 2010, 23:25 -
WVC1 in .wmv playback problem with MPC-HC
By andreyi in forum Newbie / General discussionsReplies: 6Last Post: 23rd Jan 2010, 12:35 -
How to add streams to WVC1 (WMV HD)
By ChileanGuy in forum Video ConversionReplies: 0Last Post: 21st Jan 2009, 12:16 -
wvc1 codec
By pixel zombie in forum MacReplies: 2Last Post: 26th Nov 2007, 14:18
