Help. I thought my computer monitor was dying so I bought a new one, because the picture was getting darker and darker, and I could barely watch DVDs anymore. With my new monitor everything is bright - but so bright it hurts my eyes. when I darken the setting on the monitor, the desktop and internet look fine but videos and dvd movies are now really dark. (it's like on default settings videos show normal but the desktop etc are too bright, and when I lower the brightness on the monitor or the nvidia settings the desktop looks ok but now videos come out really dark.) I installed the latest nvidia drivers, and used the tool to calibrate the picture with nvidia's "run display optimization wizard" but when I calibrate the gamma to what it tells me to. It comes out much much darker.
Any idea how to fix this problem?
Video may be using overlay settings and those would be separate from your desktop video card settings. You should have some overlay settings on your video card software.
Normally video looks darker on a computer monitor than a TV, but that doesn't seem to be your problem.
EDIT: What jagabo said.
I went to that screen you have shown, but when I move the tabs down or up and hit apply, nothing changes, I even moved them all the way down to 0 and hit apply and still no change? the preview screen on the right shows the changes but nothing more than that?
What player are you using? The player must be set up to use video overlay. Only one program at a time can use Video overlay so if you have both the control panel and a video up at the same time only one will change.
Also, as long as the video overlay settings are at their defaults, most players have their own color and brightness settings.
Google is your Friend
Can't get aspect ratio 16:9 to fill the screen when play DVD movies.
By Herbert Smith in forum DVD & Blu-ray RecordersReplies: 2Last Post: 15th Sep 2010, 07:37 -
= bright and dark
By beetlespin in forum EditingReplies: 6Last Post: 16th Aug 2010, 19:38 -
Have an avi, but dark. Can I make it bright?
By ssalim in forum EditingReplies: 2Last Post: 15th Feb 2008, 12:51 -
Screen & Movies To Dark
By DJboutit in forum Newbie / General discussionsReplies: 2Last Post: 26th Dec 2007, 18:19 -
How to fix a too bright & too dark issue?
By kinglerch in forum EditingReplies: 5Last Post: 6th Oct 2007, 00:37
