Hey, I need some help. I have a problem with VirtualDubMod, it saying when I try to open a .mkv it says (only handle s_text). I load the file into MKVmerge GUI (I'd use that but the subtitles come out all screwed up when I try to extract), and it says they are VOBsubs. The thing is, I have VOBsub installed on my computer and it wont open the .mkv file.
Does anyone know where I can get the plug in to extract VOBSUB subtitles with VirtualDub Mod.
Anime on Laserdisc is teh awesome
I try and all I get is this garbage
in one file
D \ O! 5 F' 43\#K $1C3K0 13x1,3O AE$E1$,A 1R1q1$QPcC_C PC1Q1Srq_!}-5) ѴQ2ѲQ1s1=_ 11$A#7 +!O7!1QQ1Q_ ++R_ R1Q11Q_7 QQqQ_ Q1QqQqQ11 AAAOQq9995 )r|),1O/! (;$;$; CO@G?3 ! 3
in annother
timestamp: 00:00:00:033, filepos: 000000000
timestamp: 00:00:02:102, filepos: 000000800
timestamp: 00:00:04:471, filepos: 000002000Anime on Laserdisc is teh awesome -
I dont think I set the program up right. I downloaded the program but it was in spanish so I didnt know what I was doing. I was just putting file extensions in that box that came up.Originally Posted by TheLaserdiscAnime on Laserdisc is teh awesome
I don't know if this helps or not, as I didn't quite understand your problem. You extracted 2 files right - an IDX and a SUB file? The IDX contains the timestamps and the SUB file contains the image files of the subtitles. It's supposed to be gibberish when opened in something like Notepad. It's not a text file as it would be if you OCR'd to some other format such as SRT or SSA. Together the IDX and SUB files are the VobSubs.
Vobsub freezes when installing and selecting the directory for virtualdub
By toprun91 in forum SubtitleReplies: 3Last Post: 9th Dec 2016, 10:40 -
Interesting Build of VirtualDub/Mod
By Soopafresh in forum Video ConversionReplies: 8Last Post: 12th Oct 2012, 01:49 -
VobSub/VirtualDub Install Problem
By locoblacbelt in forum SubtitleReplies: 0Last Post: 18th Jul 2008, 12:35 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
Encoding audio with VirtualDub MOD
By GangstaRap in forum AudioReplies: 5Last Post: 19th May 2007, 08:20
