I'm trying to put together some smallish mp4s for FastStart on download.
I'm confused with the MP4Box parameters. It looks like '-inter' is used and "all meta data are placed first in the file...." but if you also use the '-flat' parameter for "faster storage" it says that "all meta-data is placed at the end of the file." What happens if you specify both on the command line?
Also any general consensus for the duration parameter of -inter? I've been using 300. My files are on average about 2Megs in size if that makes any difference but some as small as 500K and some as big as 10M -thx-
Results 1 to 1 of 1
ffmpeg vs mp4box
By leandro in forum EditingReplies: 7Last Post: 21st Apr 2012, 09:16 -
24 FPS in mp4box?
By Prodige440 in forum Video ConversionReplies: 4Last Post: 7th May 2011, 10:51 -
qt-faststart
By spark3y in forum ffmpegX general discussionReplies: 1Last Post: 12th Jan 2010, 15:24 -
MP4Box-help
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 4th Dec 2008, 22:01 -
ffmpeg faststart option? for progressive dl viewing
By kosso in forum ffmpegX general discussionReplies: 0Last Post: 22nd Aug 2007, 06:21
