Hello Everyone,
I have a couple questions so I thought putting them in here might be the best place. I apologize if it isn't.
I am trying to accomplish 1 thing but using a couple different dvd formats.
First, not that it necessarily matters but at least you'll understand my motivation of doing it and doing it right the first time.
I have a 1tb drive I want to store my audio/video files on. I'm a C5/C6 quad and need help everytime I want to watch a movie. So I'm tryng to store them digitally on a drive and play them from there.
I just bought my first blu ray player and started buying the movies.
I stumbled across the WD USB to HDMI converter this weekend for $69.95, the price was a misprint but BB still honoered it.
I need help converting the movies so I really want to try to get it right the first time. What is the best way and highest quality way to put both my regular and blu ray movies onto my drive and play them using the WD media player?
My computer is runnng XP and it only has a stadard cd/dvd burner in it.
I appreciate the help.
Respectfully,
Dennis
Dennis Tomlin
Dream it, Believe It, Do It... Nothing is impossible.
http://millbrookofficesupport.com -
If you don't care about space, you can rip your movies to the hard drive with something like the freeware DVDFab HD Decrypter. Or you can use DVD Shrink to choose just the main movie and the preferred size and play it back as an ISO or VIDEO_TS folder.
Blu-ray will need to be ripped with a program like AnyDVD and a Blu-ray computer drive. $$
Unless you want to use about 25GB of hard drive space for the ripped file, you can convert them to MKV or similar high quality formats with something like RipBot264. Takes quite a few hours.
There are other ways to do both operations, but the setups above work well.
And welcome to our forums.
The first step is to get a copy onto your computer. You can use an app such as DVDFab HD Decrypter to rip the movies onto your HDD. After they are on your HDD, it is simply a matter of choosing a format and encoding. The formats of choice would be Divx/xvid (avi) or h.264 (mkv).
Google is your Friend -
Thank you very much for the help and welcome.
Dennis Tomlin
Blue-ray Drive Hookup
By mccoady in forum ComputerReplies: 10Last Post: 7th Jul 2011, 14:51 -
The new Power DVD 9 - to play Blue-Ray disks
By orfajackson in forum Newbie / General discussionsReplies: 3Last Post: 17th May 2009, 13:49 -
Very new newbie, Blue Ray drive and now movies are grainy
By tpmrcp in forum Software PlayingReplies: 3Last Post: 11th Nov 2008, 08:33 -
How to play virtual Blue Ray Disks?
By alexv305 in forum Software PlayingReplies: 8Last Post: 9th Jun 2008, 15:20 -
Can anyone recommend a Blue-Ray SATA Drive for my Media PC?
By the_importer in forum Media Center PC / MediaCentersReplies: 36Last Post: 30th Mar 2008, 12:27
