I have several large avi files that were created when I used Windows Movie Maker to edit some concerts. I am left with files of 20Gb or more and was wondering what converter I should use to enabled these to be reuced to fit unto a standard dvd or what format I could convert them to in order to play on a standard dvd player?![]()
https://www.videohelp.com/tools/sections/all-in-one-dvd-converters
I use FAVC. If you want something even easier try DVD Flick or ConvertXtoDVD. -
Welcome aquergunk
A: Dvdflick may be the simplest option to go from avi to dvd
B: Avidemux is a good tool to either convert or compress the avi to a smaller file size so it will fit onto a single disc
C: If default wmv, use windows movie make to output as dv avi (then go with A or B) ... or windows media encoder (to keep wmv, but make smaller file)
A bug in previous line > or B -
If you want to split a DV AVI file into ~4GB segments you can use VirtualDub in "Direct Stream Copy" mode. Each segment will be playable and editable. There will be no degradation of picture or sound quality.
You can also use a tool like HJSplit to break the file into segments. But the individual segments won't be playable. You have to join them all back together again before you can play or edit the video.
None of the above will be playable on a DVD player.
Reducing the size of a very large .mkv
By ChienBleu in forum Video ConversionReplies: 2Last Post: 20th Mar 2011, 08:19 -
how to burn large avi files
By movelikeme in forum Newbie / General discussionsReplies: 7Last Post: 13th Nov 2010, 06:04 -
Converting rips to large .avi files
By HartsVideo in forum Video Streaming DownloadingReplies: 2Last Post: 24th Jul 2009, 23:32 -
Burn large MKV file onto several DVD-R disks
By fazza8 in forum Authoring (Blu-ray)Replies: 3Last Post: 11th Jan 2009, 07:28 -
How to break large vob file into two disks?
By chobo321321 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 13:53
