Hi
I've constructed a video consisting of 4 other videos (4-way split screen). However the audio that is in the video disappears when I save the file using avs2avi. (the other encode option doesn't works, fails something to do with missing command line parameters).
Any suggestions as to how I can get it to save?
a = AviSource("C:\xy\1a", audio=true)
b = AviSource("C:\xy\2", audio=true)
c = AviSource("C:\xy\3", audio=true)
d = AviSource("C:\xy\4", audio=false)
e = AviSource("C:\xy\5", audio=false)
f = AviSource("C:\xy\6", audio=false)
StackHorizontal(stackvertical(a,b ) , StackVertical(c,d), StackVertical(e,f))
Thanks!!
AVS2AVI won't save audio, it's video only.
Try loading your AVS file in VirtualDub -
Save your work in AVSP as an AVS file - File--->Save As
Then load the AVS in virtualdub
How do I do a side by side video comparison in AvsP?
By Simcut in forum Newbie / General discussionsReplies: 15Last Post: 25th Mar 2012, 23:42 -
Error message in AvsP
By carlmart in forum Video ConversionReplies: 4Last Post: 15th May 2011, 09:10 -
Avsp won't start
By vidalien in forum EditingReplies: 12Last Post: 14th Mar 2010, 17:04 -
avisynth
By sportflyer in forum Newbie / General discussionsReplies: 1Last Post: 16th Feb 2010, 04:36 -
Using avisynth
By bsuska in forum Video ConversionReplies: 8Last Post: 16th Jul 2009, 08:32
