Hi:
Just the other day I installed the above mentioned Cyberlink Power Director v7 on my computer. I played around with it a little just to see what I could do. The problem came about when I attempted to use the "Create" function within the software I got the following messages:
Components initialization failed. There might have been problems during installation. Please reinstall again.
Creat Disk page initializing error! Components initialization failed. There might have been problems during installation. Please reinstall again.
I have uninstalled and re-installed four times now with the same error message. Is there some special codec(s) that I need or is it something else entirely.
Any help would be greatly appreciated.
Thanks,
Consider supporting us by disable adblocker or buy Replay Video Capture or PlayON and record Netflix!
you could try the latest update patch. i've used it a few times but it has always been a bit buggy.
Originally Posted by lapetite_66
The file(s) in the BurningMgr folder of PowerDirector is damaged. You need to replace them with a non-damaged ones (2 files total). The files are the same for other installations also so you can just copy the files from another installation (including the trial version). -
You need the original Burning Manager files from the trial version find them here:
http://cid-c313ccef48a58781.skydrive.live.com/self.aspx/.Public/BurningMgr.zip
Originally Posted by lapetite_66 -
ALL YOU NEED TO DO IS DOWNLOAD A DVD MENU. Your Install contained no DVD menu. The program requires at least one DVD menu to funsction!
It's a fantastic program. I just found the solution elsewhere.
To get DVD MENU'S login/register in directors zone and then navigate to DVD menus and download one. Double click it and it will install. Then you can burn a disk!!!!!
How do I lap dissolve with Cyberlink Power Director
By tonycopple in forum EditingReplies: 1Last Post: 27th Aug 2011, 19:05 -
Cyberlink Power Director does not recognize widescreen
By sektionschef in forum Video ConversionReplies: 4Last Post: 4th Aug 2009, 23:56 -
JVC HDD Camcorder/Cyberlink power director file import error
By lonewolf_mb in forum Newbie / General discussionsReplies: 7Last Post: 29th Dec 2008, 21:53 -
i have trouble with "Cyberlink PowerDirector6" capture from Turtl
By Chief ADFP in forum Newbie / General discussionsReplies: 6Last Post: 7th Apr 2008, 19:09 -
Cyberlink Power Director Problem
By ada1984 in forum EditingReplies: 6Last Post: 17th Nov 2007, 11:50
