Hi!
Im cutting my first shortfilm and need some tips about transitions.
What transitions are preferable to use in these scene:
__________________
__________________1) Two people are sitting and talking in a coffee shop
2) They dissagree about something and are starting to discusse heavily
3) One of them are getting on the bike and are leaving the coffeshop
How to cut between these three scenarios. (each scenario consists of many clips which I cut with straight clips) but how do I best cut between 2) and 3). with what transition?
my options between 2) and 3) is (without order):
a) crossdisolve - fade one picture into another
b) straight cuts here aswell
c) fade in fade out dissolve
d) fade out in one clip, but without fade in. so it goes straight into a straight clip
e) straight cut and then fade in to the next clip.
the transition might be preferable?
when using the options c) d) e)? when is one preferable if front of the other and is it some of these techiques that are very seldom used?
thanks for your help!
Per
My 2 cents
Dissolves are best used to show scene change or time lapse. Cuts are used within a scene.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
ok, thanks.
which dissolve are preferable to use than in the described scenario:
thanks
Per -
I like c) for a scene change.
I like a) for landscape scenery transitions.
And I like cuts for reverse dialog.Recommends: Kiva.org - Loans that change lives.
Avisynth. Stumbled audion while Dissolve()
By egochnpp in forum EditingReplies: 4Last Post: 4th Feb 2012, 07:26 -
How do I lap dissolve with Cyberlink Power Director
By tonycopple in forum EditingReplies: 1Last Post: 27th Aug 2011, 19:05 -
Low Quality on Dissolve Transition with Photos
By mattgx in forum EditingReplies: 22Last Post: 26th Jun 2009, 19:58 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05 -
Edge artifacts noise caused by transitions/dissolve effects.
By baculus in forum EditingReplies: 6Last Post: 25th Jun 2007, 17:07
