Hello all,
I am new here and, alas, I have a problem. It seems that Mencoder on my server tries to convert all files in a list at once instead of one by one causing the server to cresh. How can I make mencoder convert 1 at a time?
Thank you in advance.![]()
Well I am not the coder of the server but I can try and get it for you. Its a real pain though , so any help will be greatly appreciated if I can find it....
This is absolutely crazy. The script owner as said this:
There is no fix for it. It's a server issue and there is nothing that can be done within the script to fix it. You just need to limit the number of files that you import at a time, especially if they are large in file size.
So where on earth do I start? I have no idea where to look to limit the number converted.
Stop mencoder from printing at screen
By sokrat3s in forum Video ConversionReplies: 0Last Post: 4th Mar 2011, 02:21 -
Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 08:12 -
cannot make the a/v in sync using mencoder
By helenw in forum Video ConversionReplies: 2Last Post: 18th Sep 2009, 10:45 -
mencoder converting realmedia files w/audio sync problems
By kruuth in forum Video ConversionReplies: 9Last Post: 26th Sep 2007, 15:34 -
Problems converting files using either mencoder or ffmpeg
By krisbee in forum LinuxReplies: 12Last Post: 21st Sep 2007, 07:26
