Hi Guys! I wasn't sure where to post this, so I chose Newbie. Anyways, I am fairly new to the whole HD Concept. I was wondering is there a way to get the VC-1 Codec, and what is it exactly, should I use it or stick to another format? Will VC-1 work on my X-Box 360 and P3? Thanks for your time and help!
Windows Media Encoder and WMP11 should be enough for VC-1 encoding. The Xbox360 supports it, but I am not sure if the PS3 does. AVC is probably the more universal choice at this time.
Read my blog here.
I dont think the PS3 will decode WMA Pro audio so dont use that when creating your files.
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Which Codec's is Best To Use?
By Artic in forum Video ConversionReplies: 4Last Post: 26th May 2010, 15:39 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
BD Codec?
By kinglerch in forum Blu-ray RippingReplies: 4Last Post: 1st Aug 2008, 21:26
