  1. Member romanstopme's Avatar
    Mar 2008
    i started having trouble with my avg lately. i have the paid version. my avg keeps on saying that the anti-spam is disabled but i never change any settings to disable it. also when you update it always says that there is no new updates even though i know there should be and it never updates by itself. it says that you need to up date about every hour even if i change the setting to update once a day. any suggestion on how to fix this.
    We don't stop playing because we grow old; we grow old because we stop playing.” (George Bernard Shaw, 1856-1950)
  2. Member isogonic's Avatar
    Jan 2003
    @localhost
    You can take a look around here:
    http://www.avg.com/us.support
    Some malware can also disable, prevent updates or cause other issues with AV and anti-malware apps. Malware free?
    Feb 2004
    Australia
    Update ever hour is ridiculous.
    A: Ccleaner (garbage out)
    B: Try malwarebytes > http://www.malwarebytes.org/ (seek and remove)
    C: Hijackthis (Chase out non-existant files, be mindful of any listed "nameservers")
    D: Winsockfix > http://majorgeeks.com/download4372.html
    E: Reset windows firewall defaults > http://www.winxptutor.com/sp2/resetfw.htm
    If you have any other secondary firewall, antispyware products running, disable those to test avg's ability to connect for updates.
