i am trying to copy a protected dvd with dvd fab but i get errors while doing it!
i also tried dvd shrink but i cant either!
is their any other software that allows my to copy with no problem?
Results 1 to 12 of 12
Is your version of DVDFab updated? How recently was the DVD released? Some newer discs use revised copy protection schemes that may take the Fab guy a little time to overcome. Sooner or later, you'll be able to back up the disc you own -- unless it is defective. Just make sure your DVDFab version is up to date.
the newest version!filmboss80
Posted: Dec 27, 2008 17:06
5.2.2.0 -
If DVDFab HD Decrypter won't do it, not sure what the problem might be. If it's a Sony disc, probably ARccOS protection, not CSS. But Fab should still be able to rip it. Maybe a damaged disc or just a very new form of protection.
i dont think its new because the movie im trying to copy is THE INCREDIBLES
and it came out 2004 so i dont know what the problem is?
i just tried dvd decrypter but everything i try seems to fail at 36 percent!
what else would you recommend me doing? -
Seems the likeliest explanation.Originally Posted by redwudz
Pull! Bang! Darn! -
It may be a damaged disc.
Look over the surface carefully. If it has any large scratches, that might be the problem. If it's smudged, try washing it off with a mild soap and water and drying it with a soft paper towel. Sorry, I can't come up with much else. It doesn't sound like a decryption problem if the disc has been on the market that long.
Better look again..... the newest version as of DEC. 24th is 5.2.2.2Originally Posted by just
3 days before this thread.
8) -
Try a different drive. LG's are better readers of marginal and/or protected discs than Lite-on's, in my experience. To put it another way, when my Lite-on craps out with RCC errors, my LG almost invariably reads the disc OK. Sometimes it's very slow, which the LG is capable of doing, and it could take several minutes to get past a bad spot on the disk or a particular protection scheme.
You can also pop 'The Incredibles' into the search box up there ^^^ and find threads from when it was a new movie...Some folks copied it using good old DVD Decrypter.
Thank you to all for the replies but i was able to copy it!
And yes it is terribly scratched..
The program i used to copy it was CLONEDVD 4...i took a lil bit but it did the job the other couldn't!
im definetely going to purchase it.
Copy Copy-Protected VHS to DVD
By abazabam in forum MediaReplies: 36Last Post: 12th Feb 2012, 02:25 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
copy protected DVD
By marcelcukier in forum DVD RippingReplies: 12Last Post: 7th Oct 2008, 09:36 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 11:23
