Hi, im writing here to ask professional guidance on burning a DVD on my Mac
Just recently, one of my friend gave me a VIDEO_TS Folder which i don't really like leaving it on my computer (it takes up quite some space)
SO i got Toast Titanium but the problem is when i try to Burn the Movie in the selection of VIDEO_TS Folder, it appeared a weird error saying that the Folder im trying to burn has a CSS encryption and that Toast is not allowed to burn and stuff like that.
And following on some of the forum's suggestion, to burn it through (UDF) and to create an extra AUDIO_TS folder, but at the end after the disc is burnt, the verification process shows an error saying Sector 0 is Unreadable, Verification Failed, So i decided not to verify but surprisingly, there wasn't anything written on my disc!!!
im somehow out of ideas on how to burn this on my DVD+RW disc....
Use ImgBurn to burn the VIDEO_TS folder to a DVD...Originally Posted by bguguen
When you open ImgBurn, choose MODE > BUILD. Then, choose FOLDER, point ImgBurn to VIDEO_TS folder, then click OK. Hit the CALCULATE button, to make sure that it is the correct size to fit on the media you are using, then click the burn button, and you are good to go..."Better to reign in Hell than serve in Heaven" ~ JOHN MILTON, PARADISE LOST -
Mate, is there any software for Mac OS X??Originally Posted by HmNtr
If your "friend" incorrectly ripped a protected DVD and left the CSS in place then nothing will burn it as your cannot burn CSS encrypted material. You will have to remove the protection first, which is difficult. You may be able to turn the folder into an ISO image of a DVD, mount it as a virtual drive, then re-rip it.
Of course it may not be protected at all, in which case it is probably just poorly ripped and should be binned.
Go back to your "friend" and have him burn you a copy himself, or rip you a decent copy.Read my blog here.
bguguen, it would be helpful if your filled out your computer details so we wouldn't have to guess what OS you are using.
I'll move you to our Mac Forum where you may get more Mac specific advice. -
Sometimes Toast incorrectly messages that it finds encryption when there is none. I don't know what triggers it, but I believe it only finds that in Video mode.
Try to burn as a DATA disc, format DVD-ROM (UDF), with a proper disc title (ALL_CAPS_NO_SPACES), adding your VIDEO_TS folder and adding an empty AUDIO_TS folder. I'm pretty sure it won't complain about encryption then.
It still could be a bad rip, though, which may cause playback issues. To test it without wasting a disc, in Toast, save as disc image. Mount that image as a virtual disc. Play the virtual disc with Apple DVD Player, which is much more strict that VLC, and will likely show the same errors as a set top box, if any. -
Case, I have a similar problem and I'd like to try your suggestion. I have burned a movie as a data disc before but I've forgotten how to do that. Would you mind posting some simple instructions?
We have since found that the false indication of encrypted content is triggered by the use of "[" and "]" characters in the folder and file names. Simply avoiding those should prevent the message.
The exact wording may depend on your version of Toast. Set Toast to burn a Data disc. Select the DVD-ROM (UDF) file system. Drag files and folder onto the Toast window; i.e. the VIDEO_TS folder and AUDIO_TS folder. Remove any ".DS_Store" file from the list. Name your disc. Save as Disc Image or Burn.Originally Posted by Mark-Leon
Burning a VIDEO_TS folder to disc makes it a playable DVD right ?
By Bansaw in forum Authoring (DVD)Replies: 25Last Post: 1st Mar 2015, 15:34 -
Avi->DVD no Video_TS folder
By gaikoku in forum ffmpegX general discussionReplies: 7Last Post: 13th Sep 2008, 12:11 -
Burning VIDEO_TS folder to a DVD disc as Video not Data
By xtaint in forum Authoring (DVD)Replies: 2Last Post: 3rd Aug 2008, 08:23 -
Using Nero Ultra: How Do I Use Video_TS Folder ---> DVD
By MacPCConsultants in forum Newbie / General discussionsReplies: 6Last Post: 28th Nov 2007, 06:16 -
VLC - plays DVD from video_ts folder?
By qpskfec in forum Software PlayingReplies: 9Last Post: 21st Nov 2007, 13:38
