    Dec 2008
    I am just starting to capture video to edit. I have captured about 30 hours of MiniDV tapes so far, from years of family events, All the video is on my PC as .AVI files. Each tape is more than a DVD can hold, and I don't need all the video on DVD anyway. A couple clips I have published to .WMV files for viewing on my PC. Do I need to save the original .AVI files as well since these files are hard disk hogs? Will I be able to burn DVDs from the .WMV files??? My assumption is that the tapes will at some point degrade so I want to make sure I have video archived in a format that allows me to do other things with it when the tapes are gone.
    Thx,
    Dan
    Jan 2007
    Republic of Texas
    No, no, no! Avoid wmv like the plague. It will compress your video to ugliness. Stay in the DV-AVI realm, and then encode directly to mpeg2 for DVD using one of the programs listed here:
    https://www.videohelp.com/tools/sections/video-encoders-mpg-dvd
    ConvertXtoDVD may be your easiest solution.
    And NEVER erase your original recordings. MiniDV tapes tend to last much longer than harddrives and DVD-R discs.
