Need to crack my Sony DVP-SR200P DVD layer to play region 2 DVD's, PLEASE help me!
There are 2 issues with foreign DVDs -- region coding and video systems standards. Region 2 discs from Japan are of the NTSC standard and will play in US DVD players, but region 2 discs from Europe or Egypt will not because they are of the PAL system.
Although there are no region hacks listed for your particular model, you can back up a region 2 disc to a region-free DVD-R using DVDFab HD Decrypter. -
Sony players typically support region free or they don't. Very few are actually hackable, and the ones that are, require special hardware, not a simple remote hack. From what I can find, this player is not hackable, but the suggestion above by filmboss80 may work for most discs.
Google is your Friend -
solution for Sony DVP-SR200P CRACK REGION FREE CODE ON A REGION 4
Hi guys,
Try this:
1.Switch on the player
2; Pop open the CD compartment
3. put the dvd you cant see and as it is reading...
3. Enter the following code (using the remote): 2812
it work for me I have region 4 and I need to see a region 1
SONY BDP-S350 how to crack region codes from its own menu?
By madfogs in forum DVD & Blu-ray PlayersReplies: 24Last Post: 26th Aug 2015, 18:00 -
Sony DVP-SR200P -- Playing CDs In Repeat Mode Without a TV
By maico996 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Jun 2012, 15:57 -
Sony DVP-SR200P problem
By Andy312 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Feb 2012, 19:53 -
need help hacking into my sony DVP SR200P
By candace1978 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 21st Dec 2010, 10:36 -
Playing region free DVD on Sony SR200P DVD Player
By merik in forum DVD & Blu-ray PlayersReplies: 5Last Post: 25th Nov 2009, 16:35
