I have a ripped DVD with audio only in the right channel. Can I somehow edit the VOB files to make it audible across both channels in mono?
My ultimate goal is to encode this to mp4. I tried doing so with handbrake, setting the "mixdown" to mono, but the resulting file had no audio at all.
Is there some other encoding software that would mix the right channel to mono during the conversion process, or do I need to edit the VOB files before encoding? What software would do this?
Thanks!
Thanks Baldrick. AviDemux did it, but the current version produces mp4s that are unplayable on QuickTime, so I ended up using Nero Recode, which also successfully created a mono channel and plays on QuickTime.
The one issue, is that playback with QuickTime is very CPU intensive. It uses over half of my Core 2 Duo, producing a choppy screen. Meanwhile, VLC plays it fine. What's up with that?
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 11:32 -
AC3 File: Audio only on left channel
By koberulz in forum AudioReplies: 10Last Post: 25th May 2011, 12:07 -
Left channel drops after compression-- any tips?
By buddyreid in forum MacReplies: 3Last Post: 24th Sep 2009, 09:44 -
Converting a Mono Left Channel to Double Mono Left/ Right Channel on a DVD
By socool135 in forum AudioReplies: 5Last Post: 16th Sep 2007, 00:45 -
My VCR's Left Channel Died
By moviebuff2 in forum Newbie / General discussionsReplies: 17Last Post: 29th Jun 2007, 11:24
