I'm trying to edit videos I've created with my Toshiba Gigashot A40FE with Premiere CS4. The gigashot saves videos as mpgs (which appear to be highly compressed H264), which premiere only imports if renamed to .avi. It seems though that the combination of full HD resolution along with the highly compressed H264 makes premiere screech to a halt (2.4ghz c2d).
After reading these forums it seems the solution is to convert the video files to a format which is less compressed so that premiere doesn't choke on the video files. I'm also resizing the videos (don't really need the full HD quality) to further reduce cpu/disk usage.
Most people here recommend cineform, but that is not an option for me due to the price, so I decided to use MJPEG instead. I use Xvid4PSP for this purpose because it's free and it's the only converter I got to properly import the original mpgs created by the cam (avidemux gives an error about the aspect ratio).
I was successful in creating an avi with the mjpeg codec, which plays back fine in media player classic & vlc. The problem is that when I import it into premiere, premiere plays the video back at something like 10x speed. Does anybody know how to fix this? Could it be a problem with the mjpeg codec or with Xvid4psp?
I'm a complete newbie so any help would be greatly appreciated!
	You could try another codec and see if it works better in premiere. Like huff lossless, dv-avi(only 720x576 video).
	Thanks for your reply. I tried the huff codec but when I try to import it, premiere gives the error "unsupported format or damaged file".
	NO NEED TO DO LENGTHY WORK OF THAT KIND IF U HAVE MAINCONCEPT PLUGIN PRELOADED. OR IF U HAVE LITTLE EXPERTISE IN AVISYNTHESIS SCRIPT AND ALSO PLUGIN NEEDED FOR PREMIERE PRO.
 NO NEED FOR FORMAT CONVERSION FOR FURTHER QUALITY LOSS AND ALSO TIME. REALTIME EDIT IF U HAVE QUADCORE PROCESSOR ALONG WITH COREAVC DECODER OR FFDSHOW DECODER.
	Had the same problem, and found the solution on a dutch forum: rename the file from .mpg to .mts. That's it!
  Can you import from Adobe After Affects to Adobe Premiere Pro?By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43
  Adobe Premiere ElementsBy willmington in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2011, 04:14
  Adobe Premiere created 0k files and I cannot delete them (SOLVED)By mazinz in forum ComputerReplies: 5Last Post: 16th Apr 2010, 23:29
  Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 04:17
  Adobe Premiere CS3 vs 2.0By hanugro in forum Video ConversionReplies: 0Last Post: 31st Aug 2007, 08:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
