Are there any software apps that embed subtitle files into mpeg2?
bits
Yes hardcode/permanent subtitles. Does avidemux accept mpeg2 video? I will give it a go!Originally Posted by Baldrick
EDIT: I am working with avidemux and I am a bit confused (my usual state of mind) about how to use avidemux. can I load an mpeg2 file that has not been demuxed, then choose the subtitle filter+subtitle file and then output as a mpeg.ts?
Thanksbits -
I think I have AviDemux working. I have created an mpeg2 with embedded subtitles but I have to work on getting the correct mpeg output. If you leave video as Copy you can not choose a filter so I am re-encoding using DVD (lavc). To embed a complete re-encode is required so I think I am on my way!Originally Posted by Baldrick
Thanks again.
My process flow in summary: DVDFab 5 ---> Video_ts ---> VRD ---> mpeg2 ---> AviDemux ---> mpeg2+embedded subtitle.bits -
I am new to subtitling so my lingo is off....I want my subtitles to be hard coded into the video and I am willing to re-encode provided I can re-encode to similar settings from the original mpeg2 file. What I am finding is that AviDemux has some sort of throttling built into the DVD (lavc) and I can not output an mpeg2 with a bitrate higher than around 2.5Mb/s.Originally Posted by guns1inger
I am playing these files using a network media player that does not play ifo or iso nor mkv....therefore mpeg2 with hard coded subtitles should work.
Looks like I am SOL though.bits
Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.
By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 14:31 -
Possible to embed 'optional' subtitles to a video file?
By Apollonas in forum SubtitleReplies: 4Last Post: 5th May 2010, 13:05 -
how to embed subtitle on avi video??
By yunakokimama in forum SubtitleReplies: 2Last Post: 3rd Feb 2010, 03:28 -
How to embed subtitle and reduce file size to be playable online? [SOLVED]
By mriddler in forum SubtitleReplies: 3Last Post: 5th Apr 2009, 07:38 -
How do you embed timecode to file?
By neftv in forum Video ConversionReplies: 0Last Post: 30th Aug 2007, 15:56
