i know to use the ifoedit to find if its ntsc or pal on a video_ts, but thats about it
how can i find the region code and whter or not its a pal/ntsc
for imgs/iso/ and video_ts
I don't know of any programs that can inspect images this way. Perhaps others do. One way to do it would be to mount the image with Daemon Tools and then use something like DVD Decrypter to see if it has any region code on it. You could use IfoEdit or GSpot to see if the video is PAL or NTSC at that point. Backups should not normally have region codes on them unless the person who made the backup used something to deliberately set a region code. That's possible, but I don't know why someone would do that.
if it's a backup burned to disc, or ripped to your PC, 9939% it's NOT region coded!!
You can open the disc in DVD Decrypter and it will tell you what the region code is & if it's PAL or NTSC by looking at the reported resolution and framerate.
If it is an image mount it to a virtual drive and again, use DVD Decrypter.
If you already know how to tell with ifoedit from the video_ts folder..... why are you asking how to tell from a video_ts folder 8) -
i cant seem to figure out how to find out if its ntsc/pal with dvd decrypter,Originally Posted by Noahtuck
can anyone tell me how, i searched but only finding info that im not looking for
i can find out if its pal/ntsc on video_ts wit ifoedit, but thats it, i cant the region code with ifoedit
or use ifoedit on img/iso files
so basically this is what i want to know
video_ts - how to find the region code (1,2,3,4,5,6,7,8)?
iso/img - how to find out if its ntsc/pal?
i have dvd shrink, ifoedit, dvddecryptor, pgcedit
Converting DVDs from Region 1 (NTSC) to Region 2 (PAL)
By Astronautilus in forum Authoring (DVD)Replies: 8Last Post: 10th Feb 2012, 05:35 -
Pioneer DV-220V - region change code and PAL?
By EVG in forum DVD & Blu-ray PlayersReplies: 1Last Post: 29th Apr 2010, 11:34 -
Making a Region 1 Player Region Free. Can't find code.
By KitanaAsh in forum DVD & Blu-ray PlayersReplies: 3Last Post: 9th Feb 2010, 09:28 -
Converting PAL Region 2 to NTSC region 1
By bevluvsrats in forum Video ConversionReplies: 10Last Post: 21st May 2008, 10:15 -
Backup DVD9 NTSC to DVD5 NTSC in a PAL environment
By kroppkaka in forum Newbie / General discussionsReplies: 6Last Post: 11th Jan 2008, 04:00
