I've got a bunch of Ogg Vorbis audio files, and I want to convert them to ac3. I haven't found anything thus far that's able to do it. I'm mostly interested in figuring out what's wrong with (or what I'm doing wrong with) BeSweet, but I'm willing to look at other solutions.
I started with were ogm files. I batch demuxed them with OGMcleaver. It gave me avi video, two ogg vorbis audio streams, and two srt subtitle streams.
Here's what happened when I tried to convert the files with BeSweet. The Command Line pops up for about a second, and then nothing. There's no output file, and the log is completely blank. The command line probably shows an error, but it's gone before I can read it.
I've tried demuxing the audio with VirtualDubMod, but it doesn't help. I've opened the ogg file with audacity, and it appears to be fine so I don't know what's wrong.
				Results 1 to 10 of 10
	Hi.
 Try something like this.
 The pause will halt the batch file and give you time to read.
 Needs https://www.videohelp.com/tools/Aften
 and http://kurtnoise.free.fr/index.php?dir=BeLight/&file=bsn_20070513.zip
 Put them in the BeSweet folder.
 Change the path to reflect the location of BeSweet on your PC. Save the two lines of code to a text file. Call it something exciting, like test.bat.Code:for %%a in ("*.ogg") do "C:\VidAud\Besweet\BeSweet.exe" -core( -input "%%~dpna.ogg" -output "%%~na.ac3" ) -ssrc( -rate 48000 ) -bsn( -exe aften.exe -b 256 ) pause
 Put it in with the ogg files & double click on it.
	Alright. It didn't give me an error message. I still have no idea what's wrong.
 C:\Documents and Settings\my name\Desktop\New Folder (2)\Oggs>"C:\Program Fi
 les\BeLight-0.21\BeSweet.exe" -core( -input "C:\Documents and Settings\April Kro
 ll\Desktop\New Folder (2)\Oggs\zx.tenchi-universe.10.divx5-Audio2.ogg" -output "
 zx.tenchi-universe.10.divx5-Audio2.ac3" ) -ssrc( -rate 48000 ) -bsn( -exe aften.
 exe -b 256 )
 BeSweet v1.5b31 by DSPguru.
 Using Ogg Vorbis v1.0 dlls (http://www.vorbis.com).
 C:\Documents and Settings\April Kroll\Desktop\New Folder (2)\Oggs>pause
 Press any key to continue . . .Last edited by rayden54; 8th Jan 2012 at 23:05.
	Hmmm.
 Let's try later ogg codecs.
 The site is Japanese. These are the ones I use. These are the ones I use.
 http://www.geocities.jp/aoyoume/aotuv/binary/vorbis_dll_aoTuV_b5.61.zip
 Unzip and copy to BeSweet folder, overwriting all.
 Try again.
 p.s. '@echo off' will tidy up the screen output by NOT echoing the command line back at you.
 Code:@echo off for %%a in ("*.ogg") do "C:\VidAud\Besweet\BeSweet.exe" -core( -input "%%~dpna.ogg" -output "%%~na.ac3" ) -ssrc( -rate 48000 ) -bsn( -exe aften.exe -b 256 ) pause
	Using the above batch file I got this result.
 I notice the version for Ogg Vorbis is incorrectly displayed.
 Using Shibatch.dll v0.25 by Naoki Shibata & DSPguru (shibatch.sourceforge.net).
 Using bsn.dll replacement by dimzon, Build Sep 26 2006, 16:33:50
 [00:00:00:000] +------- BeSweet -----
 [00:00:00:000] | Input : D:\a\coyote.ogg
 [00:00:00:000] | Output: coyote.ac3
 [00:00:00:000] | Floating-Point Process: No
 [00:00:00:000] | Source Sample-Rate: 48.0KHz
 [00:00:00:000] +---------------------
 Aften: A/52 audio encoder
 Version SVN
 (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al.
 input format: WAVE Signed 16-bit little-endian 48000 Hz stereo
 output format: 48000 Hz stereo (2/0)
 SIMD usage: MMX SSE SSE2 SSE3
 Threads: 4
 progress: 0% | q: 238.4 | bw: 58.0 | bitrate: 256.0 kbps 0:51:435] transcoding ...
 [00:01:16:087] Conversion Completed !
 [00:00:01:000] <-- Transcoding Duration
 Visit DSPguru's Homepage at :
 http://DSPguru.doom9.net/
	The archive you gave me seems to be invalid or non-existant, I'm not sure which.
	I did. It appears to download instantly, and then when I try to open it, it says the archive does not appear valid.
	It's probably because I'm looking at it from a different angle. (Down Under. geddit? geddit?)
 Try this.
 vorbis_dll_aotuv_b5.61.zip
  Dimzon's bse_FAAC.dll not included with BeSweet or BeLight as advertisedBy Jedi787Plus in forum AudioReplies: 6Last Post: 23rd Oct 2010, 14:02
  How to convert .BUP and .IFO to AIFF, AU, FLAC, M4A, OGG Vorbis or WAVBy MLK3329 in forum Video ConversionReplies: 6Last Post: 5th Oct 2010, 21:13
  besweet, belightBy volam in forum AudioReplies: 0Last Post: 9th Sep 2009, 21:53
  Features not listed: udf, multisession, ogg/vorbis and matroska supportBy Lucas Malor in forum DVD & Blu-ray PlayersReplies: 8Last Post: 21st Jul 2008, 10:17
  Ogg Vorbis to xvid conversionBy mattr in forum Newbie / General discussionsReplies: 2Last Post: 4th Jan 2008, 06:21
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
