I have the latest version of MKV2VOB and I can easily convert my mkv files to vob. The problem is that whenever I try to go into the folder where the vob file is saved, Windows Explorer stops working and restarts. This only happens in folders where the converted vob files are. Can this problem be solved? Please help.![]()
Windows explorer probably tries to preview the vob video files and it crashes everything. So try disable the explorer video preview, see http://ings.ca/jim/2007/08/29/disable-avi-preview-in-windows-explorer/
Isnt there a better solution for this problem?
I get the exact same thing. Disabling the preview altogether is possibly drastic?
Vista and Windows 7 both have problem with Indeo IV50
By paj692 in forum Software PlayingReplies: 1Last Post: 8th Jan 2010, 20:30 -
Problem with Vobsub in Windows Vista 64 bits
By Talayero in forum SubtitleReplies: 7Last Post: 30th Aug 2008, 11:23 -
Windows Vista 64 bit, problem
By reinnie in forum Capturing and VCRReplies: 3Last Post: 16th May 2008, 09:08 -
VFAPI problem on Windows Vista (Home Premium)
By foochuck in forum Video ConversionReplies: 1Last Post: 3rd Nov 2007, 19:10 -
Windows Vista Problem :(
By 1magus in forum DVD RippingReplies: 5Last Post: 24th Jul 2007, 23:08
