Hello,
I have a avi xvid this file has 12 bit sample rate.
When i use virtualdub to put permanent subtitles in the video.
It looks great en there is no out of sync.
But the video has no longer 12 bit sample rate but 24 bit.
Is this oke? Could you tell me how i get 12 bit?
I hope you can help me.
merry christmas
gr Cowabunga
Don't worry about it. That sample size report from Windows is telling you something about the colorspace of the video that was compressed. "12 bit" means the video that was sent to the compressor was YV12. "24 bit" means the video that was sent to the compressor was RGB.
If you open a video that outputs YV12 (MPEG, Divx, Xvid, etc.) and compress it with VirtualDub in Fast Recompress mode (the YV12 frames are sent directly to the compression codec) you will get a video with file properties that say "12 bit" because YV12 has 12 bits per pixel on average. But if you want to do any filtering in VirtualDub you have to use Full Processing mode. In Full Processing mode VirtualDub converts the YV12 frames to RGB (24 bit) to do the processing. When this is sent to the compressor it marks the file as "24 bit".
If you want the video to report "12 bit" even though you've used Full Processing mode you can force VirtualDub to convert to YV12 before sending the video to the compression codec. Video -> Color Depth... set the Output Format to "4:2:0 Planar YCbCr (YV12)". After processing in RGB VirtualDub will convert to YV12 before sending frames to the codec. Otherwise the codec will do the RGB to YV12 conversion (assuming a codec that uses YV12 internally) before it starts compressing.
virtualdub: input video distorted on 32 bit but not 64 bit
By iggogg in forum EditingReplies: 18Last Post: 5th Oct 2011, 01:34 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 09:40 -
Question about Bit Rate and Quality
By T375 in forum Newbie / General discussionsReplies: 4Last Post: 20th Sep 2010, 09:31 -
Can't get AC3ACM to show up in VirtualDub on Windows 7 64-bit.
By teapot in forum Newbie / General discussionsReplies: 8Last Post: 17th Jun 2010, 13:51 -
Simple bit rate question
By Bully9 in forum Newbie / General discussionsReplies: 5Last Post: 8th Jan 2009, 12:01
