  1. Member joelson's Avatar
    May 2004
    Brazil
    Hi ALL!!
    I have a recorded DVD.
    It has those prints on it, which means it was really recorded.
    However, when I try to play it, it says the disk is blank (on computer) or a no-disc message (in stand-alone player).
    What might have happened?
    Thanks in advance for the help!
    Best regards,
    Joelson.
  2. recorded on what? with what? what is a "prints"?
    possibly not finalized in a dvdr recorder.
  3. As the previous poster has said the disc is most likely unfinalized or the finalization process has not been successful.
    Put the disc back into whatever you used to record it and try to finalize it.
  4. Member joelson's Avatar
    May 2004
    Brazil
    WHen I wrote "prints" I meant those mark on the back of the DVD, meaning it's not blank.
    I guess it was recorded in a stand-alone recorder (I didn't record it).
    THanks for the help!
    Best regards,
    Joelson.
  5. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    The disc likely wasn't finalized.
    Google is your Friend
