I have a Daewoo dvd player, (I think it is a dvds150) which used to play everything I threw at it (all dvd+rw, dvd-rw, dvd+r, dvd-r, all regions, etc.) but now plays only Region 1 discs.
I checked around and there is no firmware update available.
My question is this:
Is it possible to simply open the player and replace the dvd drive with another dvd-rom drive which I know plays all discs and regions?
John
Possibly. You can open it up and see if it uses a standard DVD ROM, but I wouldn't bet on it. And the new drive would still be region limited. It would probably be easier to replace the whole player with one of the inexpensive Philips units that can also play Divx. Probably only $10 - $20 more than a DVD ROM drive. You can unlock the region on some Philips units.
And welcome to our forums.
I'd just go buy a Philips or Magnavox DVD player from Walmart or Target. They are routinely in the $30-60 range. You'd pay more for a DVD-ROM drive. The Philips unit would play everything your old one did, plus DIVX/XVID, and some other stuff.
Liteon LVW-5045 replace DVD drive, project started...
By dainova in forum DVD & Blu-ray RecordersReplies: 18Last Post: 5th Apr 2011, 07:04 -
Can I replace the DVD drive in a Pioneer 533H-S ?
By gwoiler in forum DVD & Blu-ray RecordersReplies: 37Last Post: 24th Nov 2010, 23:42 -
HP Pocket Media Drive. Anyone know how to replace the drive?
By Denvers Dawgs in forum ComputerReplies: 5Last Post: 3rd Jul 2009, 16:08 -
Help on Choosing a DVD-Rom Drive
By scustalow in forum DVD RippingReplies: 1Last Post: 13th Jun 2007, 12:04 -
hd-dvd rom drive
By computerchuck in forum Software PlayingReplies: 6Last Post: 8th May 2007, 08:55
