    Dec 2008
    I've been repeatedly trying to convert one of my videos from RMVB to AVI - however, it always fails to fully convert and though ffmpegX says that the encoding process is done, the actual AVI file is only a partial clip of the original video. Is there a way to solve this problem? Thanks so much for your time.
    Here's the description if that would help:
    Encoding started on Wed Dec 24 00:35:58 PST 2008
    FIXME:Hardenabling SSE and SSE2 without detection
    MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team
    Mac OSX static build for ffmpegX
    CPU: Intel Pentium III Katmai/Pentium III Xeon Tanner (Family: 6, Stepping: 6)
    CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
    Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
    Something went wrong, no index chunk found on given address (255319294)
    success: format: 0 data: 0x0 - 0x5d885b8
    REAL file format detected.
    Stream description: Audio Stream
    Stream mimetype: audio/x-pn-realaudio
    Stream description: Video Stream
    Stream mimetype: video/x-pn-realvideo
    Stream mimetype: logical-fileinfo
    VIDEO: [RV40] 384x288 24bpp 29.000 fps 0.0 kbps ( 0.0 kbyte/s)
    [V] filefmt:11 fourcc:0x30345652 size:384x288 fps:29.00 ftime:=0.0345
    Error: dlopen(/Library/Application Support/ffmpegX/reallib/drvc.so, 1): no suitable image found. Did find:
    /Library/Application Support/ffmpegX/reallib/drvc.so: unknown file type, first eight bytes: 0x7F 0x45 0x4C 0x46 0x01 0x01 0x01 0x00
    Error: dlopen(/Library/Application Support/ffmpegX/reallib/drv4.so.6.0, 1): image not found
    dec audio decoders
    AUDIO: 22050 Hz, 2 ch, s16le, 32.0 kbit/4.54% (ratio: 4005->88200)
    Selected audio codec: [ffcook] afm: ffmpeg (FFmpeg COOK audio decoder)
    Opening video filter: [expand osd=1]
    Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
    Opening video filter: [scale w=384 h=288]
    Opening video decoder: [realvid] RealVideo decoder
    lVideo section of the DOCS!
    VDecoder init failed :(
    Read the RealVideo section of the DOCS!
    Selected video codec: [rv40mac] vfm: realvid (Mac OS X RealPlayer 9 RV40 decoder)
    MP3 audio selected
    c to 58564944 [DIVX]
    VDec: vo config request - 348 x 240 (preferred colorspace: Planar I420)
    VDec: using Planar I420 as output csp (no 0)
    Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
    SwScaler: FAST_BILINEAR scaler, from Planar YV12 to Planar YV12 using MMX2
    videocodec: libavcodec (384x288 fourcc=58564944 [DIVX])
    Writing header...
    ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
    Writing header...
    [a whole bunch of 1 duplicate frame(s)!]
    CBR audio: 16000 bytes/sec, 384 bytes/block
    Flushing video frames
    Writing index...
    Writing header...
    Video stream: 590.871 kbit/s (73858 B/s) size: 102159498 bytes 1383.172 secs 33123 frames
    Audio stream: 128.000 kbit/s (16000 B/s) size: 22111872 bytes 1381.992 secs
    Encoding completed on Wed Dec 24 00:40:38 PST 2008
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Originally Posted by Takius
    Video stream: 1383.172 secs
    Audio stream: 1381.992 secs
    Is there a glitch in the movie at 0:23:03 (1383 secs) that might be interpreted by the software as an End Of Fiile? Video errors are known to cause conversions to halt.
    Dec 2008
    I'm... not sure? :S Is there a way to fix the glitch?
  4. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    A glitch/file error in a movie clip may show during playback as extreme blocking, wrong colors, video noise, possibly accompanied by sound errors like hissing, silence, ticking. The error itself may last for only only a fraction of a second, so pay close attention around the time 0:23:00 - 00:23:05, during playback. If you see or hear nothing unexpected, then the cause of conversion error is less obvious.
    There is no easy way to repair such errors, that I know of. It would likely be easier to track down and download an AVI version of the same content.
    You could capture the playback in RealPlayer to a new file with a tool like iShowU, which can capture almost anything that happens on your screen, but the file better be unique and very important before dedicating to so much extra work.
