Hi.
Looking to buy a Sound Card
Must have (optical digital out for connecting to home cinema systems.)
I was thinking of buying the following
Creative Sound Blaster X-Fi Xtreme Gamer - Sound card - 24-bit - 192 kHz - 109 dB SNR - 7.1 channel surround - PCI - Creative X-Fi Xtreme Fidelity - low profile
http://accessories.euro.dell.com/sna/productdetail.aspx?c=uk&l=en&s=dhs&cs=ukdhs1&sku=...186&lid=121454
Can i get anything better or the same cheaper then £70
I Would like some help from anyone who knows about this stuff. I'd be grateful for some opinions!
Optical digital out not very common.
I have that card plus another similar one. Hard to go wrong with Creative Labs.
It also has the capability to capture surround sound as a digital wav thru the SPDIF connector.
You may have to get the optional extra front panel attachment in order to get optical out. -
Turtle Beach makes very good audio cards.
Turtle Beach Montego DDL 7 has all the features you requested and is quite affordable (as long as you're referring to SPDIF as digital-out) The only thing to be aware of is that it currently has no drivers for Vista.
http://www.newegg.com/Product/Product.aspx?Item=N82E16829118006
M-Audio also makes excellent audio cards
M-AUDIO Revolution 5.1 (as long as you only need 5.1). Great card, look at the Digital Out connection on it to be certain you have the proper connector:
http://www.newegg.com/Product/Product.aspx?Item=N82E16829121122 -
Here :-
http://www.dabs.com/productview.aspx?Quicklinx=4R6Z&SearchType=1&SearchTerms=creative&...ationKey=50450
As my friend has already said, and confirmed by the reviews, you will need some extra component for home-theatre and that will push up the cost. -
Thanks to all that replied for your time and help much appreciated!
do sound cards do downmixing on their own?
By dioxholster in forum Newbie / General discussionsReplies: 8Last Post: 27th Apr 2012, 05:16 -
Sound cards for dummies?
By Haopengyou in forum AudioReplies: 10Last Post: 9th May 2010, 06:35 -
Video Cards???
By HotDamn! in forum ComputerReplies: 5Last Post: 7th Dec 2009, 20:34 -
Which of the 2 sound cards for games & midi audio files
By retroborg in forum ComputerReplies: 2Last Post: 7th Oct 2008, 14:00 -
Video cards
By zinc in forum ComputerReplies: 14Last Post: 26th Jul 2008, 15:47
