I am one of those that believes a little knowledge is really dangerous. But in this throw away electonic age, I don't know if I should throw this TV in the dump or if it's something simple. I would think that if it were bulbs, they would go out one at a time...I assume there are three.
So could this be a fuse gone bad? Can anyone help me and advise what to do?? I like this TV alot and it's not my primary but great for the kids gaming.
Hugh
Could be any number of things, most of which you likely shouldn't be trying to fix on your own. Assuming you've tried the simply things such as changing the channel or input selection, is it showing anything at all? If it isn't even showing the channel of other setup options, then the video circuitry is likely hosed. Your best bet would be to have a tech take a look at it and then decide what to do based on what they tell you.
Google is your Friend
Sony Vegas - Picture-in-picture video creation
By jeanpave in forum EditingReplies: 5Last Post: 14th Dec 2011, 00:01 -
[Sony Vegas 9] Problem with Picture-in-Picture (Track Motion)
By BramJ in forum EditingReplies: 1Last Post: 27th Jan 2010, 05:52 -
PC powers off
By alegator in forum ComputerReplies: 7Last Post: 31st May 2009, 11:30 -
Panasonic ES46V Powers Off
By rgoubitz in forum DVD & Blu-ray RecordersReplies: 2Last Post: 17th Apr 2008, 20:54 -
computer powers on, will not boot
By Dr_Layne in forum ComputerReplies: 9Last Post: 12th May 2007, 00:51
