help getting ready for Christmas i have a rca dvd recorder and a jvc vhs-c camcorder i'm ruing av cables to the front of my rca dvd recorder and on my cam i put the yellow wire in and the white wire and i get a bad noise threw my speakers on my tv i unplugg white wire it goes away i'm wanting to record 2 dvd kids christmas any help will be greatly appreciated need any other info just ask thanks alot
wildky
Results 1 to 9 of 9
It sounds like a poor ground - try using a different cable.
"I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
(NO MAN IS JUST A NUMBER)
be seeing you ( RIP Patrick McGoohan ) -
Yellow Wire should goto the Video input of the recorder. The Red and White plugs should connect to the Audio inputs on the recorder. Is this how you have it connected?
tryed diffrent wire bought a new one last night need longer anyway and yes bodyslide but there isnt a red one on the camcorder just yellow and white
Wildky, if the output on the camcorder is yellow, that means it is a video output. Of course you will get terrible noise plugging it into an audio port. If you only have a white audio out, it must be a mono camcorder. (Hard for us to tell, since we don't know the model number of your JVC.) If that is the case, you might need to use a y-adapter to feed the one mono channel into the stereo inputs on the DVD recorder. However, some recorders allow you to plug into the left channel only (as I recall), and the circuitry will lay the audio down on both tracks. Look at the manual for your DVD recorder to see if that will work. Come to think of it, you should also look at your JVC camcorder's manual to confirm the types of outputs you have, and whether the audio is stereo or mono.
Merry Christmas. -
Hello wildky.
Obviously, your camcorder has monoral audio only.
You didn't provide the model numbers of your JVC camcorder or RCA DVD recorder, so I'm just guessing.
-Have you tried yellow to yellow for video; white audio out jack on the camcorder connected to the red input audio jack on the RCS DVD recorder ?
In the case of a monoral signal input, your DVD recorder could be input-specific; that is, the red input jack could be the only acceptable option for receiving monoral audio. Your owner's manual should provide specific information including possible menu settings regarding this function.
Also, be sure to check for any particular settings in your camcorder's menu specific to dubbing.THREADKILLER !
References on File. -
i got yellow to yellow and white to white i'll see if i can get u the model #'s
wildky, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
My Laptop not recognising my JVC DV Camcorder
By topcat0001 in forum Capturing and VCRReplies: 7Last Post: 29th Aug 2010, 10:42 -
Tracking problem with JVC camcorder.
By The-Geek in forum Newbie / General discussionsReplies: 0Last Post: 28th Aug 2010, 11:23 -
JVC mini dv camcorder
By biancoape in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 14th Feb 2010, 08:14 -
Camcorder JVC used as webcam
By wrummmmm in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 11th Jul 2009, 06:56 -
JVC GR-D750 Camcorder
By didikai in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jul 2007, 11:11
