So does this player not support this??
I have a ton of anime episodes that are 848 x 480 H.264/MPEG-4 AVC and I have had to convert them with ALLToAVI into Xvid and 640 x 392 or 396 can't remember and Subtitles get somewhat cut off but I can at least read about 80% of them but when I converted the H.264 avi's I get pixelation sometimes when I am watching them...
why???
I wish My Philips DVP5992 played H.264 because I was thinking about getting the New WD TV: HD Media Player, but I mainly bout the DVP5992 because of the USB Support it makes Watching Movies a lot easier and anime episodes before I would make hundreds of DVDs just to watch a 30 minute show. I am so mad that this WD came out like right after. I want to buy it but 100 bucks more....I wonder if it is worth it. Also do you need to change the Video Resolution to make it play on the WD HD Media Player or will the 858x480 work without converting??
I hope a Firmware update comes out so I can watch my H.264 858x480 Anime episodes without having to Convert them. Also is the latest firmware for the 5992 the best to have or was the original?
Firmware updates won't add h.264 support.
And yes, the WD unit should play your files without need for conversion. It handles resolutions upto 1920x1080.Google is your Friend
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
Philips 5990 or 5992 Freezing Up?
By Lance Uppercut in forum DVD & Blu-ray PlayersReplies: 31Last Post: 19th Oct 2009, 15:11 -
philips 5992 firmware upgraded..avi files not playing which played before.
By phollow in forum DVD & Blu-ray PlayersReplies: 2Last Post: 18th Dec 2008, 23:05 -
Philips 5992 DVDP?? I am using USB 2.0 How do I organize?
By sandman423 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2008, 18:15 -
Philips DVP5990/5992 in Canada?
By max6166 in forum DVD & Blu-ray PlayersReplies: 22Last Post: 11th Oct 2008, 02:07
