Hi,
I am using Samsung VP DC-171 with +RW media.
Recorder formats these disks only in VR mode (not mentioned in the manual)
After shooting 7 scenes everything looks OK, the problem is when I try to author this disk.
I see only 5 VOB files in the VIDEO_TS folder.
Scenes start and stop somewhere in the middle of the files.
Till now I can not found a software which can recognise exactly where scenes start.
Shall I import all VOB in one single VOB file and then manually extract scenes?
Pls, what is the easiest way to produce a home-made DVD?
You're confused.
You need to extract the video by its IFO data, leave the VOB files alone.
http://www.digitalfaq.com/dvdguides/edit/dvdrecorder/recorderedit.htm
DVD+VR is a subset of DVD-Video (unlike DVD-VR).Want my help? Ask here! (not via PM!)
First - Merry Christmas!
Solution still not found.
DVD Decrypter found 7 chapters (and 3 cells?) in IFO mode but reading errors appeared at 99%. Seems like damaged disk, but I do not believe in that.
Sorry, should be posted in newby section.
rgrds/pl -
Try a better DVD drive to read the disc. Try ISO Puzzle to read the ISO. Then load the ISO via DaemonTools, then do the Decrypter thing from that volume to get at the video from the IFO level.
Strangely the second disk was read (DVD Decrypter) with almost no errors. (plenty of: Sector xxxxxxxx- Pack Header Not Found (0x00000000))
But chapter info seems to be lost - it ended with one big VTS_01_1.VOB file.
How I can preserve chapters for future editing?
Shall this work: Options - IFO Mode - Create additional files - Chapter information xxx ?
tks.
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 13:21 -
Recording in LP or EP Mode -- DVD
By cbehr91 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 19th Jun 2010, 09:16 -
Why is Imgburn DVD Function buried under Mode>Build?
By jimdagys in forum Newbie / General discussionsReplies: 27Last Post: 1st Dec 2008, 19:48 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 16:27 -
Questions about dvd + vr mode
By heman28 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 24th Feb 2008, 18:53
