I have Quicktime, Realplayer, Flash player, Adobe Reader, Outlook Email Client, and other plugins installed on my computer. I presently have IE 6 installed. When I change to Foxfire, will Foxfire use these plugins, or does it have its own version of them?
It somewhat depends on whether you make FF3 your default browser; in the sense of whether you'll need all of these.
Under Tools>AddOns you will find helpful utilities for handling all the 3rd party accessories.
One I recommend is IE Tab, it opens Explorer inside a Firefox tab. There are a lot of other incredible plugins, add-ons, and themes tho- have fun!
You'll need to install Flash, Shockwave, Quicktime, and maybe Realplayer for Firefox. I'm not sure on the last one. No one really uses Realplayer if they can help it. I'm fairly certain it should pick up Adobe Reader without a problem. There is no built in link to Outlook in Firefox, but it will interface with it fine if that is your chosen email client. Click a mailto link in FF and it'll launch it in Outlook.
Also, must have extensions IMO.
AdBlock Plus (subscribe to easylist)
NoScript (I you want more security. Comes at the cost of some user annoyance at times)
Linkification
IE Tab -
Go ahead and change to FF. It is a MUCH better browser. It runs all the programs that you mention. The only problem that I have with it is that it doesn't stream Windows Media Player files (blame MS for this). FF2 would run it with a plugin, but FF3 doesn't have a newer, FF3 compatable one. I have work-arounds for sites that I want to stream.
The ability to customize the look and feel of FF3 is pretty nifty. I really like the plugin "FireGestures".ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
video browser
By butterflies in forum Software PlayingReplies: 8Last Post: 29th Jan 2010, 05:13 -
Question how to selectively delete most used web entries in Foxfire
By jimdagys in forum ComputerReplies: 4Last Post: 19th Jun 2009, 00:59 -
What web browser do you use, and why?
By louv68 in forum ComputerReplies: 21Last Post: 21st Jul 2008, 21:07 -
Best Web Browser for OS 9.1
By blinky88 in forum MacReplies: 1Last Post: 26th May 2008, 17:11 -
How YOU get a Ghost In Your Browser
By ahhaa in forum ComputerReplies: 3Last Post: 3rd Jul 2007, 17:20
