I converted a movie to DivX using Avi.net. It looked beautiful, but had sync issues. I tried to fix things with Virtualdub, but couldn't do a very good job. I then thought that there was something wrong, because usually with Virtualdub, i can do a pretty good job fixing sync issues. I decided to do a virus scan, and gee whiz, i found so many critters lurking around on my HDD. I think i found and zapped most of them. I know that viruses and other malware can affect the speed of a PC, so i think it should be a pre-requisite to do a virusscan before ever doing any video processing of any kind. I think i'll finally be able to fix my DivX movie.
If anyone has any comments, let's hear them.
	The likelihood of the virii directly causing the sync issues is pretty low, however the overall effect on your system may be a contributing factor. It would depend on just what they were, and what they were doing.
 I would be concerned that these didn't show up until you actually ran a scan. This would imply that either you aren't running a real time scanner, or that they were dormant inside an archive that hadn't been opened yet, in which case they were doing anything to your system (yet)Read my blog here.
  Emsisoft Anti-MalwareBy Teac23 in forum ComputerReplies: 4Last Post: 11th Apr 2011, 09:55
  Rendering problems with after effectBy mogoyon in forum EditingReplies: 1Last Post: 8th Dec 2010, 22:06
  Videora now full of MALWARE!By Putana in forum DVD RippingReplies: 6Last Post: 4th Oct 2010, 13:25
  Malware from SUPER?By Yamitora1 in forum ComputerReplies: 6Last Post: 6th Mar 2010, 22:43
  Are cookies considered malware?By alegator in forum ComputerReplies: 6Last Post: 8th Jul 2009, 17:24
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
