I use Premiere Pro 1.5 to edit my videos for YouTube.
I want to use another software such as WinFF or virtualdub to convert my video into another format.
My source is standard definition miniDV NTSC 720 x 480 widescreen mode.
Is the following the correct method of getting the original quality video out of Premiere Pro uncompressed?
1.) File > Export > Movie
2.) Click "settings"
3.) Under "General" - File type: choose "Microsoft DV AVI"
4.) Under video:
- choose "DV(NTSC)"
- Frame size: 720 x 480 v 16x9
- Pixel Aspect Ratio: D1/DV NTSC Widescreen 16:9 (1.2)
- uncheck "limit data rate to __" and uncheck "recompress"
6.) Under Keyframe and Rendering, check "deinterlace" and "optimize stills".
7.) Click OK
Note: I will let the WinFF or virtualdub change the pixel aspect ratio to 1:1 and the video to 640 x 360.
Also, does it matter whether Premiere Pro or another software such as WinFF does the deinterlacing"
Or you could install the Debugmode Frameserver and serve directly out of Premiere to virtualdub without an intermediate encode.
Understand that DV is compressed - at a ratio of approx 5 : 1. What you want to avoid, if possible, is re-encoding. This is dependent on what you have done in Premiere. Any footage you have applied filters to will be re-encoded. Any titles, any stills, and transitions etc will also be re-encoded.
Would I let premiere deinterlace ? No. I would do that in avisynth, which has superior deinterlacing methods.Read my blog here.
I am using Debugmode frameserver now but I have to deal with choosing RGB24 and RGB32 and I have not idea what these are.
If I use the settings given in the original post, will my video be compressed?
I can also choose "Microsoft AVI" rather than "Microsoft DV AVI" when exporting movie. When I choose "Microsoft AVI", I can choose "none" as the compressor. So will this give me an uncompressed video?
Which is the better option?
Does Adobe Premiere Pro need any other software?
By jeanpave in forum EditingReplies: 23Last Post: 17th Oct 2010, 04:37 -
Premiere Pro - Export to DVD - Taking forever
By nharikrishna in forum Authoring (DVD)Replies: 13Last Post: 12th Oct 2010, 05:47 -
Converting video from .ts format into .wmv taking forever. Help?
By pokeychris in forum Video ConversionReplies: 1Last Post: 21st May 2010, 11:29 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 17:27 -
Taking edited DV footage to DVD with Premiere Pro
By Orange_Eagle in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 23rd Mar 2008, 20:33
