Hello all you BlueRay gurus.
I purchased a Sony S350 a couple weeks ago, an LG BlueRay burner, and well as a download of AnyDVD HD and CloneDVD2. My ultimate goal is of course to backup my BlueRay disc so that they play on my standalone player. The S350 claims to play back BD-R/RW in BDMV and BDAV formats. What I am looking for is burning software which will likely have the most success with this particular unit. If you aren’t quite sure about the BlueRay player itself, which burning software tends to be the most successful? I’ve heard Nero9 is pretty good for BlueRay, but I’ve not been much of a fan of Nero in the past.
Also, can you see any holes in what I have?
Any advice will be appreciated. Thanks a ton!
Best,
Gary
I'm not aware that tsMuxeR has any ability to do more than mux/demux and author to the BD format. You would have to re-encode to change the size of the file. RipBot264 can do that or BD Rebuilder can 'shrink' the file.
burning avchd files to blueray
By alphonso49uk in forum Authoring (Blu-ray)Replies: 5Last Post: 24th Mar 2012, 15:12 -
HD PVR Software Questions
By NMeade in forum Capturing and VCRReplies: 33Last Post: 23rd Nov 2010, 01:13 -
PC > HTPC Conversion, Software and BD Questions
By fitch.j in forum Media Center PC / MediaCentersReplies: 1Last Post: 11th Apr 2010, 09:58 -
Newbie Software Questions
By AAOBill in forum Newbie / General discussionsReplies: 1Last Post: 12th Mar 2010, 23:42 -
questions on ripping software
By Mort439 in forum DVD RippingReplies: 3Last Post: 2nd Dec 2007, 21:09
I don't think
