I bought some DVDs in england, and now to I need convert it form PAL to NTSC.
Anybidy can help me?
Chico
There are several guides for doing this, but the simplest method is to buy a cheap DVD player that will play both formats. This guide : https://forum.videohelp.com/topic300144.html explains the correct method for re-encoding all the video content. Read it through to the end, as it is updated with newer software as it goes along.
Read my blog here.
Why do you believe you need to convert? Conversion is time-consuming, and inevitably degrades quality.
There are many DVD players that support both PAL and NTSC. It may be preferable to get one of those instead of converting.
If you really, truly want to convert, there are many online guides for doing so. One example of many is
http://www.digital-digest.com/articles/Convert_PAL_NTSC_DVD_page1.html
[Edit: I see that guns1inger beat me to the punch with the same advice.] -
I will try the hints tomorrow. Unfortunelly in Brazil players with supprt PAL aren't usual.
In Brazil we use PAL-M system, and the usual is find player with work in NTSC and PAL-M syastem.
In any case I will try to find any cheap player.
Thanks.
Chico -
Ah, yes; PAL-M. I didn't pay attention to the fact that you are in Brazil, where a mutant hybrid of PAL and NTSC is used. If you are not able to find a PAL-NTSC DVD player there, then you may indeed have to convert the DVD itself, using one of the procedures linked to already. It's such a pain to do that I'd use almost any other method, including repurposing a computer to play the DVD through a suitable display.
Whatever method you choose, good luck.
Tchau!
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30
