I've read that wmv is a highly compressed file.
Which file type is least compressed of these: .avi, xvid, divx, h264, MPEG-4, wmv? How can you tell?
by the filesize
but they differ in quality
what's the goal? -
AVI is a container, so it doesn't count. The rest are all highly compressed formats. If you encode with all of them at the same bitrate, the files will be the same size. Only the quality will differ. The more you squeeze, the bigger the difference. H.264 offers the best quality/size ratio of the list you have, unless you include VC-1 in the WMV category.
Read my blog here.
Uncompressed RGB or YUY2 in an AVI file is the least compressed. You need to specify what you are trying to accomplish.
Yup. What jagabo said, except that the files will be huge. Video in an .avi that is compressed with a DV codec will take 13GB per hour. Uncompressed RGB or YUY2 will be even bigger. Lagarith or HuffYUV will get you lossless compression but still at a fairly large file size. DV is a lossy compression but unless uncompressed and recompressed several times, you won't notice much difference. The others, however, you will notice a big difference if you re-encode (uncompress and recompress).
CogoSWSDSOld ICBM Coordinates: 39 45' 0.0224" N 89 43' 1.7548" W. New coordinates: 39 47' 48.0" N 89 38' 35.7548" W.
Compressed Too Small?
By OutOfBreath in forum Authoring (Blu-ray)Replies: 5Last Post: 4th Nov 2011, 18:41 -
re-editing compressed videos
By anotherkentpaul in forum EditingReplies: 1Last Post: 24th Apr 2010, 15:50 -
Best COMPRESSED video editing format in Premiere?
By Namie in forum EditingReplies: 8Last Post: 6th Jan 2010, 20:11 -
AVI and compressed 5.1
By cyanyde in forum DVD RippingReplies: 13Last Post: 2nd Jun 2008, 15:06 -
compressed capture with composite
By benaw in forum Capturing and VCRReplies: 2Last Post: 20th Nov 2007, 08:09
