I encoded an .mpg file with TMPGEnc 2.5 using 2-pass VBR.
I set the avg. bitrate to be 5991, but the final result checked in GSpot was 4350. I noticed because the file was much smaller than expected.
What could have caused this?
Source: .wmv file 23.976 fps
frame served via AviSynth
used 3:2 pulldown and unchecked the "enable padding not to be lower than minimum bitrate" box
It's not really important, the final product is fine, but I would like to know if someone could explain why this happened.
Thanks,
Chipsndukes
I played around with the "enable padding not to be lower than minimum bitrate" setting and the minimum bitrate on a different clip, and got the final bitrate in GSpot to change a bit.
So, I guess my assumption now is that 2-pass VBR will not use more bitrate than necessary unless a) forced to by a minimum bitrate or b) padding.
Does that sound right?
Chipsndukes
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 16:59 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 13:21 -
FFMPEG MPEG-2 VBR output size not coming out as expected
By DJRumpy in forum Video ConversionReplies: 1Last Post: 16th Sep 2009, 10:19 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 12:16 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50
