Anyone has an idea why this AVCHD format still works on PS3? DVD9-RW+AVCHD
cause from what I know, PS3 can't load any videos with more than Ref Frame 5, Level 5.0 and B-Pyramid.
Originally Posted by PuzZLeRThank you.Code:Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings, CABAC : Yes Format settings, ReFrames : 8 frames Muxing mode : Container profile=Unknown@5.1 Codec ID : V_MPEG4/ISO/AVC Duration : 2h 32mn Bit rate : 5 622 Kbps Nominal bit rate : 5 949 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16/9 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.269 Writing library : x264 core 65 r1024M 2652abe Encoding settings : cabac=1 / ref=8 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=6 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=12 / nr=0 / decimate=1 / mbaff=0 / bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=5949 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00 Language : English Audio Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 2h 32mn Bit rate mode : Constant Bit rate : 1 536 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Resolution : 24 bits Language : English
Message : B-pyramid level 2 detected. Shift DTS to 3 frames
By fdenis31 in forum Authoring (Blu-ray)Replies: 76Last Post: 28th Jun 2015, 15:27 -
Possible to change ref frame value w/out recoding?
By dave in or in forum Video ConversionReplies: 4Last Post: 2nd Aug 2011, 20:11 -
Change avc level and reference frame
By cote112 in forum Video ConversionReplies: 2Last Post: 24th Mar 2011, 10:45 -
PS3 Stops Playback of AVCHD?
By tommy2010 in forum Authoring (Blu-ray)Replies: 1Last Post: 15th Dec 2010, 01:38 -
AVCHD DVD and PS3
By DesossiriboNucleicAcid in forum Authoring (Blu-ray)Replies: 4Last Post: 14th Feb 2010, 14:14
