i am trying to convert the pal 2.35:1 gone in 60 seconds with tmpgenc. i cannot preserve the aspect ratio. i want to keep the screen size as it is on the dvd. anyone help?what aspect ratios do i enter in settings? cheers
That let me guess, that the source is DVD. Open the vob in dvd2avi and preview. In the statistics window you will see the source aspect ratio (probably 16:9). Then you have to resize, I assume you want to watch it on a 4:3 TV, do you? I assume you use TMPG (do you?), source aspect ratio 16:9(advanced tab),video arrange method "full screen[keep aspect ratio], target aspect ratio 4:3 (video tab). That's the simpliest way. You will waste bitrate using this method and there are some more advanced ways, but at the beginning it is OK.
Multi-System VCRs; PAL N tape, PAL VCR
By darito in forum Capturing and VCRReplies: 14Last Post: 17th Apr 2012, 11:54 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 14:36 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 13:47
