Hello, Someone knows anything about how turn region free for a dma2200 of linksys. I only know this media has a samsung tsh352c dvd player.
Thanks.
Could I change this player for another? I read that in DMA2200 it isn't possible, but I can't belive it.
A quick google search doesn't reveal anything useful. It doesn't appear to be possible with that unit.
Google is your Friend -
Could change the region code to the Samsung player, it's like a pc dvd player. What do you think?
PC based CD/DVDroms are changed via software or firmware. Keep in mind that simply being region free doesn't mean it will play everything that you want. Removing the region coding may make the discs readable, but your player and hardware then need to be able to process and/or convert NTSC and PAL video formats.
Yes, yes, you're right, but the dma 2200 has the option for play PAL or NTSC. Now I'm thinking away, Whay happens if I change the player by another player BR?, so, I could have region free and BR player. What do you think?
Thanks -
If you have discs from various regions, then I would suggest getting a player that officially supports region free.
As for Blu-Ray, most of those players cannot be hacked. There are a few exceptions, but it only applies to the DVD portion of the player.Google is your Friend
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 17:12 -
Region 1 Samsung dvd-vr375 to switch to region free
By catleo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Dec 2011, 11:25 -
Klipsch CS-500, need to make region free / code free / zone free
By Trialsman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 14:16 -
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 05:34 -
How to Make a Pioneer DVR-520H Region 1 a Region Free player?
By Ossocao in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th May 2007, 22:35
