Hi,
I'm a newbie to VideoHelp.
I have been using a DVD/VHS unit with an older TV.
Recently I purchased A Grundig PVR.
I can connect either unit and get great pictures & sound.
I purchased an RCA plug double adaptor to use both units without plugging & unplugging each time I change units.
Unfortunately the DVD/VHS won't work using the double adaptor.
It still works on the adaptor if I unplug the PVR.
Any thoughts or solutions?
affa44javascript:emoticon('')
	Get a swicth box, check your local wal-mart's gaming section you should be able to find one for less than $10.
	Thanks, nic2k4, for your suggestion - wal-mart's not in australia yet - but i'm sure a local computer/video/audio store should stock a switch box
 merry xmas
  better unit than my old wintv pvr usb2By diablo in forum Capturing and VCRReplies: 0Last Post: 9th Sep 2011, 10:52
  HP TV Tuner/PVR unit ? or Black magic Intensity pro?By TBoneit in forum Capturing and VCRReplies: 43Last Post: 11th Feb 2010, 10:35
  VHS Copy Protection when using a Dual DVD\VHS UnitBy wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25
  VHS to DVD all in one unitBy robroth in forum DVD & Blu-ray RecordersReplies: 15Last Post: 4th Nov 2008, 22:04
  Connecting a PVR to a DVD-RBy Sean08 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 8th Jan 2008, 14:53
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
