Let me describe my problems.
- AlltoAVI and a bunch of other video conversion programs doesn't want to convert my MKV files...
- So I have to use WinAvi to convert mkv into wmv/mp4 so I may import it to my zune/XBOX 360
- Which was fine for the first 17 episodes of this anime series, in which the streams were ordered English/Japanese.
- However the episodes past that point were ordered Japanese/English, so when I use WinAvi to convert them, it only catches the first audio stream, which was japanese.
I've tried to convert it to a DVD using ConvertXToDVD then to WMV using WinAvi...but I encounter messed up video/audio.
So this Is what I want to know. Is there a way to reorder the streams on a MKV? That would be the simplest solution to my problem.
You can try remove the japanese audio stream using mkvtoolnix.
Changing the order of the audio streams in a rip
By JDMils in forum Blu-ray RippingReplies: 4Last Post: 17th May 2011, 19:03 -
recommendations for swapping audio from MKV files
By tkolt in forum EditingReplies: 3Last Post: 22nd Mar 2011, 06:39 -
[Conversion] MKV with Multiple Audio and Subtitle streams for PS3
By SharanQ in forum Video ConversionReplies: 5Last Post: 23rd Jan 2011, 22:23 -
Swapping field order in progressive video.
By jmail524 in forum Video ConversionReplies: 1Last Post: 3rd Aug 2008, 13:53 -
Change order of dvd audio streams
By jujuandhuhu in forum AudioReplies: 3Last Post: 18th Mar 2008, 09:19
