  1. Hi, I had to get a new tower so I got this one:
    http://www.circuitcity.com/ssm/HP-Pavilion-Elite-m9402f-Desktop-m9402f/sem/rpsm/oid/22...oductDetail.do
    I used to use Decrypter w/DVD43 to rip one uncut VOB from a DVD then I'd edit & convert to mpeg in VideoReDo & used ULead DMF 3 to burn.
    It appears Decrypter & DMF3 won't work in Vista. I've read that though ULead claims newer version (6 & 7?) of DMF are Vista compatible consumer reviews I've come across say they don't.
    I downloaded AnyDVD & CloneDVD since they seem to work in Vista (& I like how it also removes the region coding as well as the copy protection) but it doesn't have an option to make a menu (unless I make an exact copy which I don't want to do) & it won't allow me to rip one long VOB to work with (I'd prefer to do this because if I join VOB's you can hear/see cuts where they were merged on playback), unless these features appear when my trial version is over & I buy it but it does seem to be fully functional throughout the trail version so far anyways.
    Windows DVD Maker (which came with the tower) does include a menu but it assumes you want a motion menu and I don't (since it seems to take forever to burn the disc if I have a motion menu and it automatically re-encodes the mpeg too).
    So, can anyone recommend (to a novice)... :
    1. A ripper that will allow me to rip one long VOB, and...
    2. A burner which will allow me to add a NON-motion menu w/chapters?
    Both of these need to be Vista compatible of course too.
    Thanks in advance.
    You can open all the main movie vobs as one from the dvd using videoredo( http://www.videoredo.net/msgBoard/showthread.php?t=5709 ). And run anydvd in the background and it will decrypt the video automatic or if you want something free then use dvdfab decrypter to rip the movie to your hdd and import with videoredo.
  3. Originally Posted by Baldrick
    OK, thanks for this, at least this way there was no being able to tell where the VOB's ended and the next one begun.
    Still looking for a burner which will allow me to add a NON-motion menu w/chapters though, as when I added the mpeg I made from this "combined VOB", Windows DVD Maker still had chapter markers where they were on the original DVD Video & of course the same problems (only motion menu and no menu option at all for CloneDVD).
  4. Forgot to say, I'm not doing HD or anything just regular movie mpegs.
  5. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I assume you are performing some sort of editing on the video, if not, you are copying them the hard way.
    Google is your Friend
  6. Originally Posted by Krispy Kritter
    Yes I am editing, VideoReDo has worked fine for the editing and converting (especially with their new combine option spoken of above).
    I now just need to know which burning software will work with Vista and allow me to create non-motion menus, chapters, edit the names of the chapters and burn the mpeg to disc.
