hi guys
i have a dv of of my band live converted to avi....i also have the soundboard mix on cd converted to wav...the fool recording video kept pausing btwn songs so i have to merge each song individually...i am working 1 song for now
i cropped both wav and avi for the song i want to do.....they are at 2 different starting points...probably off by a second or 2
i have canopus procoder 2..vdub.. and cool edit pro 2.0 to work with...is there anything i can do with these?
thanx
You are in for a lot of work. Each song will have it's own sync problems. You really need an editor that will let you slide around the audio track to match the video. SyncView or Vegas Movie Studio, unless someone else suggests an easier app.
https://www.videohelp.com/tools/SyncView
http://www.sonycreativesoftware.com/moviestudiope -
nope im in luck...the sync worked out fine...i found the setting to delay audio start on vdub ...the cd and dv are at the same speed....at least close enough for 3-5 min at a time for each song
if anyone has any other advice or suggestions id appreciate it anyway...seems im gonna be doing this alot....hopefully with 35-45 min sets at a time
thanx soopa im gonna look into those shortly
AVI Merge (XviD)
By Asesinato in forum Video ConversionReplies: 5Last Post: 19th Apr 2012, 05:37 -
How to merge avi files?
By mkvelidadon in forum Newbie / General discussionsReplies: 3Last Post: 26th Sep 2011, 02:25 -
How to merge wav files ?
By Benjy in forum AudioReplies: 7Last Post: 31st Jul 2010, 04:41 -
merge two avi files
By Jorge in forum Video ConversionReplies: 4Last Post: 17th Feb 2010, 22:01 -
Merge several avi:s untouched ?
By offer in forum Newbie / General discussionsReplies: 4Last Post: 27th Jul 2008, 14:19
