I have a Sony digital8 camcorder. My old power cable is missing. So, in this case I need a new power cable. One of my friends gave me a power cable for SHARP camcorder. The pin of cable of SHARP camcorder looks the same with the SONY cable. But on the power cable of Sony, the input voltage is 7V, and in SHARP is 8V. Do you think is nothing important, or is dangerous, to tray that (maybe I am gone break the camcorder) Help please.
The 1 volt difference probably won't matter, but the amp rating could be problematic, how do they compare? Also make sure the polarity matches. They may have used the same connector, but that doesn't mean that they wired it the same.
Buy My Books -
Originally Posted by gadgetguy
buy a multi-voltage adapter from Radio Shack.
they're cheap, come with a ton of plugs, and you can switch the polarity on them if necessary.
http://www.radioshack.com/product/index.jsp?productId=2049697
Or contact Sony to see if you can buy a new one from them."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 03:03 -
Are RCA/composite video cables compatible with audio cables?
By sldvd in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2011, 00:17 -
Extension cables vs Replacement cables
By Novice20 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jul 2011, 20:03 -
Is my camcorder's lithium ion battery power diminishing?
By Nintendo Fan in forum MediaReplies: 5Last Post: 17th Mar 2010, 19:03 -
JVC HDD Camcorder/Cyberlink power director file import error
By lonewolf_mb in forum Newbie / General discussionsReplies: 7Last Post: 29th Dec 2008, 21:53
