Hi.
I 'd like to ask you guys if there is a way to view a video material field by field with some tool. I just want to make sure that the jerky playback of a DVD I have is a result of "wrong field first" setting.
VirtualDub has a Bob Doubler filter. AviSynth has a simple Bob filter built in.
Well, I wanted to pause the interlaced clip at a particular field (1/50 sec in PAL), where motion occurs and then advance to next field and so on, to show up field disorder, if any.
I finally managed to do it with "preview" option of tmpgenc (after having set frame rate: 50fps, encoding mode: non-interlace and deinterlacing method: even-odd field).
nVidia NTSC TV-Out interlaced field mix-up issue
By cybertheque in forum Software PlayingReplies: 3Last Post: 19th Dec 2011, 16:55 -
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 04:12 -
Toshiba SD290 DivX interlaced field problem
By Sainsbo_McManus in forum DVD & Blu-ray PlayersReplies: 3Last Post: 1st Jun 2010, 19:35 -
Interlaced XViD playback on Standalone - Field Order Problem
By nbarzgar in forum Video ConversionReplies: 2Last Post: 13th Jul 2008, 08:04 -
Newbie frame/ field - capture both interlaced fields
By peter bradbeer in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 8th Feb 2008, 15:36
