ok, i dont just mean playing in their head, i mean the sort of echo thing. like in dbz or something they think "i gotta be super sayan" or something. like the slight echoing noise. its not like a repeated echo, its just like a faint one. how exactly would i do that? help is greatly appreciated
Try the freeware audio editor Audacity. It accepts MP3 and WAV files. Use the echo filter and also modify the sound with one of the other filters to give a sort of 'sound in a barrel' effect to make it sound like internalized speaking.
If you filter out the high and low frequencies, that may also give sort of a 'telephone' effect that may help. -
Try the GVerb filter effect. It comes close at the standard settings. Just select your audio section, adjust it the way you want, then preview. If it sounds right, process the section. Audacity is easy to use, like a word processor, cut and paste.
You can try the different effects and use the ones you like. And you can also undo any changes before saving. Here are some guides: http://audacityteam.org/wiki/index.php?title=Audacity_Wiki_Home_Page
"Live" picture effect - pictures end up "filmized"
By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 11:59 -
Using DVDLabPro to create a "sound effect" button?
By takearushfan in forum Authoring (DVD)Replies: 7Last Post: 1st Jun 2010, 19:53 -
AVS Media "demo" file-conv S/W inserts voice into cvtd music files
By charlessmall18 in forum AudioReplies: 0Last Post: 2nd May 2010, 16:17 -
Paint Shop Pro - "Sin City" effect?
By stantheman1976 in forum ComputerReplies: 5Last Post: 30th Apr 2009, 15:56 -
Eliminating "Tearing" effect in 2D games with Vsync & Triple
By retroborg in forum ComputerReplies: 1Last Post: 17th Dec 2007, 10:50
